Unkas
Myytävänä Forgen Ventus 70 pystyakseli tuulivoimala (Made in UK). 7 kpl, käytetty muutaman vuoden ajan solar-wind -led katuvalaistuksen tarkoituksiin. Hyvässä kunnossa.
Tarjoa hinta.
http://smartac.eu/Forgen-Ventus-70-tooteleht.pdf
Valmistaja: http://www.prolectric.co.uk/products/wind-turbines/vertical-axis/forgen-ventus-70-vertical-axis-wind-turbine/ventus-70-nt-(normal-temperature)/
Nominal Output: 25 Watts @ 16ms-1
Rotor Diameter: 300mm
Vane height: 465mm
Output voltage: 12VDC
Start-up wind speed: Approximately 2ms-1 (3.88knots)
Cut-in wind speed: Approximately 3.5ms-1 (7.82 knots)
Generator: Three Phase permanent magnet
Noise Level: Less than 5dB, 5m from unit
Coating: All exposed parts powder coated Aluminum, center shaft cold anodised
Bearing: Fully sealed
Temperature range: -50oc to +50oc
Wire: 10 meters standard
Mounting option: Pole mount, Wedge mount, Side mount, Rail mount
Weight: 13Kgs
Installation: Easy and simple
Warranty: 2 years
Special Features:
Safe and Silent in operation
Non blade design for user safety
No maintenance required
Corrosion resistant components
Electrical circuit fully protected against overload
Note: Result from internal wind tunnel testing. Field results may vary.
Tarjoa hinta.
Vane height: 465mm
Weight: 13Kgs
Warranty: 2 years
Special Features:
