Aurinkolämpö
Kiinalaiset "keskuslämmityspaketit" ja kimppatilaus?
<blockquote data-quote="TiJuMa" data-source="post: 7002" data-attributes="member: 4443"><p>Kyselin suoraan immerSUNilta miten tuon boxin käyttöä voisi suunnitella mainitsemallasi jäähdytys/lämmityskäytöllä.</p><p></p><p>Vastaus tässä:</p><p></p><p>"The immerSUN is designed to monitor the power being exported to the grid, and to instead divert this power to a pure resistive load (e.g an immersion</p><p>heater.)</p><p>Because the output of the immerSUN is modulated (think of a light dimmer) you can only connect it to resistive loads, other devices are not permitted and could/will be damaged.</p><p>Overall it is difficult to see how you could use the immerSUN in your off-grid system, even if you connected to the grid, it would not be possible to prevent export to the grid from happening.</p><p></p><p>The immerSUN's current 'Installation and User guide' contains more information and can be found at the link below, and on our web site."</p><p></p><p>http://www.immersun.co.uk/downloads/immerSUN%20Installation%20and%20User%20Guide%20v1.2.pdf</p></blockquote><p></p>
[QUOTE="TiJuMa, post: 7002, member: 4443"] Kyselin suoraan immerSUNilta miten tuon boxin käyttöä voisi suunnitella mainitsemallasi jäähdytys/lämmityskäytöllä. Vastaus tässä: "The immerSUN is designed to monitor the power being exported to the grid, and to instead divert this power to a pure resistive load (e.g an immersion heater.) Because the output of the immerSUN is modulated (think of a light dimmer) you can only connect it to resistive loads, other devices are not permitted and could/will be damaged. Overall it is difficult to see how you could use the immerSUN in your off-grid system, even if you connected to the grid, it would not be possible to prevent export to the grid from happening. The immerSUN's current 'Installation and User guide' contains more information and can be found at the link below, and on our web site." http://www.immersun.co.uk/downloads/immerSUN%20Installation%20and%20User%20Guide%20v1.2.pdf [/QUOTE]
Aurinkolämpö
